Failed CV Joint?
- cameronskehan
- 2006 Suzuki Jimny 1.3 JLX Facelift
30 Jul 2025 19:48 #261394
by cameronskehan
Failed CV Joint? was created by cameronskehan
Good evening gents,
Looking for some advice. There's a clunking/clicking coming from the front driver side axle that increases with the rotation speed of the wheels. When the clutch is engaged, it will jolt with a large clunk. From my research, this says failed CV joint?
I've replaced kingpins, swivel bearings, seals and diff oil, but this hasn't fixed the issue.
Video Link: youtube.com/shorts/t_znaT3oy4g
- Thank you received: 2005
31 Jul 2025 03:20 #261398
Replied by Lambert on topic Failed CV Joint?
Usually a failed CV joint results in limited steering under normal road driving as it shouldn't be rotating when in 2 wheel drive. Off road in 4x4 drive then yes a failed one will click.
- cameronskehan
31 Jul 2025 09:38 #261403
by cameronskehan
Replied by cameronskehan on topic Failed CV Joint?
Thanks Lambert, what do we think about this being an issue with the vacuum hubs?
31 Jul 2025 16:32 #261410
It is possible that the pipes have been put on the wrong ports but it is very obvious that something is not right when you drive with only one hub engaged, the noise is noa good or quiet one.
- cameronskehan
06 Aug 2025 11:18 #261492
by cameronskehan
*UPDATE*
After exhausting my limited knowledge of repairs, I took it to the garage and they believe the noise is coming from inside the gearbox. Rather than rack up a large bill of dismantling the gearbox and replacing parts, I've been advised to replace the whole unit.
Does anyone know where I could source a gearbox for an 06 VVT 5 speed manual Jimny? Ideally removed and delivered.
Thanks!
Thanks!
06 Aug 2025 13:58 #261499
by fordem
Replied by fordem on topic Failed CV Joint?
Call me sceptical, but I have to wonder how we get from "A to B", front driver's side axle to gearbox, and I want to suggest another opinion.
Maybe remove the front freewheel hubs to disconnect the hubs from the axle shafts, maybe disconnect the front drive shaft from the transfer case & front differentials - isolate that entire front axle and drive the vehicle - is the noise still present?
