Dome light Dilemmas!
- Frankandsteinpug
30 Jul 2025 13:38 - 30 Jul 2025 13:39 #261388
by Frankandsteinpug
Dome light Dilemmas! was created by Frankandsteinpug
Hi all new here and not sure if this has been covered but couldn’t find anything in a search.
I have a 2002 Jimny cabrio (new to me) and am trying to iron out some wrinkles.
the one at the moment that is really getting to me is the dome light. The passenger door works fine, but for some reason the drivers door doesn’t. The switch tests ok, and the cable checks out all the way to the connector behind the glovebox. The only oddities I can find are that a.) when testing the driver’s door switch I notice a 12v circuit on this switch- I was not expecting a reading as I thought the whole line was negative/earth? Is this normal? It doesn’t blow fuses so I am assuming so.
b.) I’ve noticed the drivers door runs through a diode before going to the dome ( connector g06) above the glovebox box if this has blown it would make sense that the circuit would be broken, but then why do I see 12v on the line? If I bypass this diode will I cause other issues?
has anyone replaced this diode? A google search only wants to find references to alternators when you reference diodes & vehicles.
does anyone know the part number to replace the diode - or what the value of the diode would be?
any help very much appreciated.
thanks
Keir
thanks
Keir
Last edit: 30 Jul 2025 13:39 by Frankandsteinpug.
30 Jul 2025 15:37 #261391
by fordem
Replied by fordem on topic Dome light Dilemmas!
A defective diode is a possible cause of your problem, the reason the diode is there is because the dome light circuit is one of several circuits that are triggered by that switch, and you don't want the other circuits triggered by the other door switches.
If you're seeing 12V on the switch wire it means the switch is either not closed, not grounded or there's a broken wire somewhere in the circuit.
30 Jul 2025 18:09 #261393
Replied by jackonlyjack on topic Dome light Dilemmas!
Have you tried swapping the switches over
So drivers side works and passenger will then be intermittent
My driver side works passenger intermittent
- Frankandsteinpug
31 Jul 2025 08:07 #261401
by Frankandsteinpug
Replied by Frankandsteinpug on topic Dome light Dilemmas!
Thanks Fordem
Figured this could be it. Interestingly I have no warning buzzer for lights keys etc. I guessed that the diode was linked to these systems.
Unfortunately the circuit diagram is at best vague when looking for the controller but as far as I can see it’s part of the instrument cluster - this can wait! I’ll try to find a replacement diode and go from there.
- Frankandsteinpug
31 Jul 2025 08:14 #261402
by Frankandsteinpug
To be honest I hadn’t as it tested ok on the metre but now you mention it I will as I have had things test up ok before but not actually work.
31 Jul 2025 12:46 #261404
by fordem
No warning buzzer AND no dome light strongly suggests a problem with the switch and or the wiring and this is more or less confirmed if you're seeing 12V on the switch wire.
IF the switch is working & properly grounded you will not see 12V on the wire with the door open.
The following user(s) said Thank You: Frankandsteinpug
Time to create page: 0.164 seconds
