Car won't move towing in 4L
18 Jun 2025 05:36 #260924 by Lambert
Replied by Lambert on topic Car won't move towing in 4L
This wasn't on a hard surface was it? And were there any associated banging noises before it started rattling?
18 Jun 2025 09:04 #260930 by Motacilla
I was towing a small trailer with a decent load of broken down furniture, and to clear a small incline i put my 3rd gen in 4Low, but when i let off the clutch in 1st gear the car wouldn't move, and something was rattling.
It sure sounds like 4L was not quite fully meshed, I think @DrRobin's experience is very relevant and @yakuza is right about likely causes.
When a gearbox gear fails, you get more than a little rattle -- you get a godawful racket that generally persists even when you are not trying the failed gear.  Plus you get lots of pretty stuff coming out of the oil drain.  After all, gears are hardened steel, so on those very rare occasions when they fail it is, as the kids say, epic.
18 Jun 2025 10:33 #260932 by Vandoni
Replied by Vandoni on topic Car won't move towing in 4L
it was on asphalt, and there were no noises apart from the rattling, i might try the 4L again today and see if the lever is a little loose and not engaging completely, because my mechanic showed it did move a little in its place
18 Jun 2025 10:56 #260933 by yakuza
Replied by yakuza on topic Car won't move towing in 4L
yank it hard aft and hold it and ease of careful on the clutch and see if it engage better.
18 Jun 2025 12:36 #260938 by fordem
Replied by fordem on topic Car won't move towing in 4L
The Jimny is part time 4WD and 4WD should NOT be used on an asphalt surface, this is clearly stated in the owner's manual, along with warnings of possible drive train damage.
18 Jun 2025 15:52 #260939 by Vandoni
yeah i read that, i'll be more careful in the future
Time to create page: 0.639 seconds
