Car won't move towing in 4L
17 Jun 2025 15:54 #260912
by Vandoni
Car won't move towing in 4L was created by Vandoni
I was towing a small trailer with a decent load of broken down furniture, and to clear a small incline i put my 3rd gen in 4Low, but when i let off the clutch in 1st gear the car wouldn't move, and something was rattling.
Once i put it back in 2H the car moved no problem without any noises out of the ordinary, and following that 4high also worked no problem, any ideas?
17 Jun 2025 16:52 - 17 Jun 2025 16:54 #260914
Replied by yakuza on topic Car won't move towing in 4L
sounds like your low gear mesh is broken but never heard of this happen before so it is not very likely...
or more likely the actuator if you have a 05 or newer push button transfer case. But then there would be blinking 4wd light on the dash I guess.
what model year is your car?
Last edit: 17 Jun 2025 16:54 by yakuza.
17 Jun 2025 18:22 #260918
by Vandoni
Replied by Vandoni on topic Car won't move towing in 4L
it's a 2000 jimny, with the non-vvt m13a, it's had its share of transmission issues (the shifter stiffening bar, if i can call it that, was welded badly from factory and detached, but we welded it back a lot stronger), had the clutch replaced not even 10k kms ago, i don't know what that could be
- Thank you received: 673
17 Jun 2025 18:25 #260919
Replied by DrRobin on topic Car won't move towing in 4L
Not the same model, but my Gen 4 has jumped out of 4L a couple of times, there is another thread on here.
Turns out, I am not the only one and everyone says you have to give the lever a good shove backwards to make sure it is correctly engaged.
If your Gen 3 is lever operated perhaps it’s the same thing?
Just to be certain, you can’t change in to 4L whist on the move, you have to be at a stop, should be in neutral and possible push the clutch in.
When I had a Gen 3 with push buttons, sometimes it wouldn’t engage 4L and sometimes it wouldn’t come out, but you always got flashing lights on the dash.
Have a look at the BigJimny wiki ages for your model there are plenty of tests and diagnostics on there.
Robin
Robin
17 Jun 2025 20:03 #260921
Body lifted?
Something bent?
Stupid aluminium transfer Mount cracked?
Rubber Mounts broken?
Rubber around gear shifter broken or shifter bent?
Try lifting the transfer from underside by hand, you will soon see if any of the above is in play.
Something bent?
17 Jun 2025 20:57 - 17 Jun 2025 20:58 #260922
by Vandoni
it is lever operated, and i made sure to yank it hard to engage the low gears.
the body isn't lifted, and when i changed the engine oil last month nothing seemed out of place or bent so i don't know.
i'll check the transfer case and the mounts when i can, but the car drives no problem otherwise so at least there's that ahah
Last edit: 17 Jun 2025 20:58 by Vandoni.
Time to create page: 0.197 seconds
