Converting to electric running
10 Jun 2025 09:15 #260841 by FFMan
noise might be an issue if low range is straight cut gears - i'll need to look into that - thanks
High range is a bit long, and will make performance sluggish.
10 Jun 2025 11:14 - 10 Jun 2025 11:20 #260842 by facade
Try taking the front prop off and driving in low. I thought the gears were helical like the diagram in the manual, they are constant mesh so I can't see them being that much louder on load than free.
The Gen4 (definitely helical, I've watched youtube disassembly videos) "sings" all the time, ( really loud with a transmission guard to reflect the noise back up- mine has sound deadening stuck to it to make it tolerable), most likely the spinning intermediate gears, I've not noticed more transfer noise in low, but I've never gone above walking pace in low either!
(Rather a backwards step using intermediate gears rather than epicyclic IMHO)
The Gen3 lever transfer is epicyclic, and pretty quiet in low.
Last edit: 10 Jun 2025 11:20 by facade.
10 Jun 2025 21:22 #260859 by Busta
My Gen3 whines like a rally car at higher speeds in low range. It's fun for a while, but might get miserable after a few miles.
11 Jun 2025 03:24 #260861 by Lambert
You might consider finding a transfer box out of an auto they are 1.3:1 in high range which might be a better ratio?
11 Jun 2025 08:19 - 11 Jun 2025 08:20 #260862 by Hughes
noise might be an issue if low range is straight cut gears - i'll need to look into that - thanks High range is a bit long, and will make performance sluggish.
After looking at some photos, they are helical cut, but a lot coarser pitch and less helical angle which will make them louder than the gearbox.
Last edit: 11 Jun 2025 08:20 by Hughes.
11 Jun 2025 08:22 #260863 by Hughes
Busta post=260859 userid=15214
Yeah same that's why I thought of it. 2wd Low is the best
Time to create page: 0.333 seconds
