Spot light wiring
04 Jun 2025 15:19 - 04 Jun 2025 15:21 #260741 by gano54
Spot light wiring was created by gano54
Hello,
I am going to be adding some spot lights to the Jimny (Gen4), and I have a question regarding power for the switch -> relay. I don't want to connect it to the high beam, and this leaves me with either a direct connection to the battery, or ACC (can only turn on when the key is in/past the ACC position). I'd rather do ACC, but do you know if there's any convenient place to get ACC from? Switch will be placed to the right of the steering wheel (OEM switch panel)
Thank you!
2022 Jungle Green LCV
Last edit: 04 Jun 2025 15:21 by gano54.
04 Jun 2025 17:31 #260745 by fordem
Replied by fordem on topic Spot light wiring
You might like to check the local laws, most places require the spot lights to be switched along with the high beams.
There are multiple places to tap the ACC line - starting with the ignition switch, followed by the accessory power socket, then the fuse panel - take your pick.
The following user(s) said Thank You: gano54
Time to create page: 0.160 seconds
