1999 jb33w OBD2 wiring
- hranmuthu@gmail.com
24 May 2025 03:37 #260570
by hranmuthu@gmail.com
1999 jb33w OBD2 wiring was created by hranmuthu@gmail.com
Dear all,
I have a 1999 JB33W Jimny, When I checked the 16 pin OBD2 like connector, I see pin 7 and 9 has wires. When I check the wiring diagram, it shows only 1 wire connected to pin 9 from ECM (I checked). I'm wondering where the other k-line wire (pin 7) is connected to. Usually k-line wire should be at 12v at rest, but it is not reading any voltage (0v) Anyone has any ideas ?
Thank you,
Harshana
Thank you,
Harshana
- Thank you received: 674
24 May 2025 07:30 #260571
Replied by DrRobin on topic 1999 jb33w OBD2 wiring
I think your Jimny will only have OBD1 and will not have K-line or other OBD2 protocols.
24 May 2025 13:38 #260577
by fordem
Replied by fordem on topic 1999 jb33w OBD2 wiring
First - are you certain the wiring diagram you're looking at is correct for your car? The FSM will usually have a short list in the first few pages detailing the chassis numbers/VINs that are covered.
The reason that I raise this is many of us have downloaded softcopies of the FSM from whatever source we can find, and they may not be correct for our specific vehicle.
Moving on, OBDII is a US federal standard that vehicles built for the US market were required to be complaint with from 1996 onward, other regulatory bodies developed similar standards, for example EOBD), many of which were based on, and are backward compatible with the US OBDII standards, but in 1999, as far as I know, only US market models would have been OBDII compliant.
TL;DR - it's highly likely your car is not OBDII compliant.
25 May 2025 13:17 - 25 May 2025 13:17 #260584
Replied by hranmuthu@gmail.com on topic 1999 jb33w OBD2 wiring
I have a set of pdfs I downloaded, it has a vin table pdf and mine is within the range. Also so far I haven't seen any problems with information given in that pdf. I'm thinking may be the pin7 wire is for 4wd controller, need to check this. I also feel it's obd1
Last edit: 25 May 2025 13:17 by hranmuthu@gmail.com.
Time to create page: 0.283 seconds
