speedometer stopped marking
15 May 2025 00:11 #260414
by JimnyCol
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
speedometer stopped marking was created by JimnyCol
The speedometer stopped working, I checked the cables and I don't see anything disconnected in the transfer case or on the dashboard, what can I do?
15 May 2025 17:02 #260421
Replied by jackonlyjack on topic speedometer stopped marking
Install GPS one on your phone
16 May 2025 07:30 - 16 May 2025 07:31 #260432
Replied by yakuza on topic speedometer stopped marking
does it count km's/miles?
if no, try changing the sensor on the transfer case.
if yes, might be the dash cluster.
easy swap but might be costly and your miles count will be from the donor cluster.
someone breaking a jimny would be able to supply the parts for cheaps.
edit: something electrical done to the car recently? try reversing it.
Last edit: 16 May 2025 07:31 by yakuza.
20 May 2025 13:30 #260504
by JimnyCol
Replied by JimnyCol on topic speedometer stopped marking
A bad connection in the dash, fixed it. Maybe too much vibration.
