Radiator electric fan
20 May 2025 20:22 #260514 by JimnyCol
Replied by JimnyCol on topic Radiator electric fan
hard to know which one is a good tech in this... ac tech you have all around, but some will only mess it out... maybe it is just the compressor which is not original so...
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
20 May 2025 22:25 #260516 by fordem
Replied by fordem on topic Radiator electric fan
I'm not a lover of "quick fixes", they inevitably create other issues that need fixing down the track.
A compressor that is too small for the system will be unable to circulate enough refrigerant, which in turn will be unable to transfer the heat energy out of the vehicle.
I'm not saying your compressor is too small, in fact the only reason I mention this is because you say it's not the original.
I learned the hard way, I literally paid to learn, and I will not fit used or "substitute" air conditioner parts, if it's not new and of the correct specification I don't want it.
20 May 2025 23:17 #260517 by JimnyCol
This is the compressor I have fitted back then:
www.amazon.com/dp/B0BTLV7MHP
Time to create page: 0.271 seconds
