Radiator electric fan
14 May 2025 23:48 #260412 by JimnyCol
Quick question, should the electric fan spin when I turn on the AC? It seems that mine is not working.
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
15 May 2025 03:20 #260415 by Lambert
Replied by Lambert on topic Radiator electric fan
Not constantly no. It kicks in and out around every 30 seconds when idling depending on the conditions.
20 May 2025 13:31 #260505 by JimnyCol
Replied by JimnyCol on topic Radiator electric fan
Is there a way to put it on running every time the engine is on? Because it starts only at 3,000 rpms more or less, and I live in a very hot area, 26 degrees is the minimum here, and under the sun, the AC is almost useless when I stop the car at a semaphore...
20 May 2025 14:39 #260507 by fordem
Replied by fordem on topic Radiator electric fan
Have the A/C system diagnosed/repaired by a reputable shop - 26*C is not that hot.  If the system is working properly, it is capable of keeping the interior of the car cool with the vehicle stationary and the engine idling with the outside temperatures approaching 40*C.
20 May 2025 16:52 #260508 by JimnyCol
I changed radiator, condenser, AC compressor, expanding valve all in October 2024, I had the gas pressure checked various times since then but the air is not so cold inside the car. Especially when the engine is idling, it won't work properly.
20 May 2025 17:59 #260511 by fordem
Maybe you missed the part where I suggested you have the work done by a reputable shop.
I've walked the road you have and been dissatisfied with the results until I found a competent person to sort it out.
Time to create page: 0.214 seconds
