06 squeak!
10 May 2025 20:21 #260357 by smalljay32
06 squeak! was created by smalljay32
Finally took the initiative to get a jimny after wanting one for a long time and am very happy with it apart from a persistent squeaking!
It starts about 15 minutes into driving and is louder and more consistent at lower speeds and seems to be coming from the driver side front wheel especially making a slight left turn. Interestingly the squeaking goes away when I brake.
It's been SORN for 3 years before being done up so hasn't been in motion for a long old while so was wondering if it could be some rust/general crud in the brakes?
Any advice is much appreciated :) thanks!
Proud father of Jep the Jimny (2006 VVT)
11 May 2025 04:31 #260360 by Lambert
Replied by Lambert on topic 06 squeak!
Easiest to adjust are the rubber screw bungs that the bonnet is supported on in the slam panel. After that it comes down to being persistent and accepting that noises don't always come from where you think.
The following user(s) said Thank You: smalljay32
11 May 2025 07:13 #260361 by Motacilla
Replied by Motacilla on topic 06 squeak!
Could be a lot of things, of course.
If it's a wheel, your best bet is to jack the car up and spin them manually until you locate the sound.
But any responses you get here would be just wild guesses.
11 May 2025 10:51 #260362 by smalljay32
Replied by smalljay32 on topic 06 squeak!
Thank you! I've given them a tighten and will see how it goes. If not I'll jack it up for further investigation next weekend.
12 May 2025 07:42 #260371 by DrRobin
Replied by DrRobin on topic 06 squeak!
The bonnet rattling is a common one, as is the dashboard, the screws (under plastic covers) come loose.
If it is under the car the rubber bushes on the various suspension arms can squeak as can the exhaust brackets, both of these often change under braking.
Although as others suggest it’s a long list of things that might cause the problem.
Does it happen a slow speed or over a speed bump, perhaps you could get someone to listen outside?
Or is it louder with a window down, that might help?
Robin
10 Jul 2025 14:21 - 10 Jul 2025 14:34 #261179 by smalljay32
Thank you so much for your suggestions!
Much louder with the window down and no relationship between bumps and squeaking. It's also much louder at lower speeds and high speeds it's more of a chirrup in the background.
Other observations -
Seems to be some relation between dry weather and it squeaking.
The more I drive it during the week (esp. In stop start traffic) the louder it is and the quicker it starts into the journey.
If I don't drive it for a couple of days it takes far longer for it to start.
If I drive down a long steep hill braking lightly for decent period it then stops the issue completely for a day or so.
Last edit: 10 Jul 2025 14:34 by smalljay32.
