Doubts on suspension parts to buy after a small lift
03 May 2025 00:13 #260295 by JimnyCol
My Jimny is a JB43, 2017, and I'm based in Colombia. The car has been lifted with a suspension kit (coils + absorbers) +4 cm by XT Automotive, and I have castor correction bushes already fitted.
Given that the coil spring seats (especially the rear ones) are partially cracked, I'm willing to buy  SHOWA GARAGE 10mm Coil Spring Spacer for Jimny , not sure if 10 mm or even 15 mm. This would bring the suspension lift to +2" approx.
For such a lift, would it be correct to buy  TANIGUCHI Rear Panhard Rod Relocation Bracket for Jimny  and  SHOWA GARAGE Short Stabilizer Links for Jimny  too, to correct the geometry now?
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
03 May 2025 03:48 #260298 by Lambert
Usually a 2 inch lift doesn't need much more than the springs and dampers and normally they drive ok afterwards. That's not to say there is no benefit to reworking the rest of the geometry but that is normally only needed on a bigger lift like 3 inches and higher. Normally. See what it drives like first.
03 May 2025 06:11 - 03 May 2025 06:12 #260300 by Soeley
The Old Man Emu 40mm lift kit comes with a rear panhard relocation bracket. During development of the kit they worked out the ride was much better with it. There is a video from OME out there, about it.
I have this kit fitted to my JB74, not added any spacers to the lift, so not looked onto the short stabiliser links.
Last edit: 03 May 2025 06:12 by Soeley.
03 May 2025 17:08 #260301 by fordem
If the original lift did not come with some form of panhard bar correction, it would mean the axle is no longer centrally located under the car, but rather, offset to one side (I think it's right), and this is before you add the additional 10~15 mm of lift.
Apart from being offset to one side, it also means that as the rear suspension cycles up/down, the extent of the offset varies, so that the tail of the car wags from side to side.
I want to take the time to point out here, that an adjustable length panhard bar as supplied with some lift kits only fixes the offset at the new ride height, the variation in offset, or the tail wagging will remain, the fix is to move one end (either one) up or down to return the bar to it's original horizontal (or parallel to the ground) orientation.
I'm not in favour of "mixing & matching" after-market suspension components, someone will have to sit down and examine how the pieces interact with the original suspension and also with each other.
The Taniguchi relocation bracket says it's highly recommended for more than two inch lifts and can even be used with one inch lifts, in reality, it has to be designed for one specific lift height (the distance by which it moves the end of the panhard bar) and use with any other lift height creates a "non-optimal" situation - it will either not centralize the axle as it should or even possibly offset it in the opposite direction. Unfortunately their website doesn't provide dimensions, it does suggest it's suitable to be used by itself, for a 20~60 mm lift - should we guess that it's really a 40mm lift correction?
Time to create page: 0.230 seconds
