Exhaust issue
- Me and my Jimny
Topic Author
- Premium Member
- Thank you received: 9
19 Mar 2025 14:01 - 19 Mar 2025 14:01 #259847
by Me and my Jimny
Exhaust issue was created by Me and my Jimny
Hi Guys
51 plate gen 3. The engine lights been on for a few years now, power feels a bit more restricted, and there is now a rattle which sounds like inside the cat. Think it's time to get a new exhaust. I've found old threads with the reference to parts in motion on ebay.
I've never done an exhaust before but looks easy to swap from the manifold to the back, but there must be some gotchas, anyone got any tips ?
Last edit: 19 Mar 2025 14:01 by Me and my Jimny.
- Thank you received: 2005
19 Mar 2025 19:08 #259849
Replied by Lambert on topic Exhaust issue
The main one is getting the oxygen sensors out. It's not impossible but it's also probably easier to accept needing new ones and ordering them to arrive with the exhaust. Just be aware there are many knock off sensors out there and they are less than reliable.
- Me and my Jimny
Topic Author
- Premium Member
19 Mar 2025 21:39 #259851
by Me and my Jimny
Replied by Me and my Jimny on topic Exhaust issue
Thanks Lambert, I didn't know about them but will check it out. I think the whole thing is from the factory so at 24 years old it's probably good to change them at the same time
- Thank you received: 676
20 Mar 2025 07:50 #259852
Replied by DrRobin on topic Exhaust issue
It could be worth getting the engine codes checked to see what the engine light is on for, it might be an O2 sensor in which case fitting new ones in the new exhaust is a good idea.
There might be some variations in exhaust fittings, but if you are replacing the whole system it should all match. The exhaust brackets/bolts will most likely shear off so order new brackets/bolts and just watch out for rusty bolts on the manifold.
Robin
Robin
- Me and my Jimny
Topic Author
- Premium Member
20 Mar 2025 10:49 #259853
by Me and my Jimny
Thanks Robin
The brackets crumbled a while ago so i already had to fashion something for that
From what I've found there are two lambda sensors, one before and one after the cat. They're the oxygen sensors right ?
So far it looks like they cost more than the whole exhaust but I haven't checked bigjimny store yet
20 Mar 2025 13:00 #259854
That's them. Like I said you might be lucky and they come out easily and still work when you put them in the new exhaust. Or more likely they will come out hard and if not dead already will die in the process and then you are waiting for new parts without the car. Of course you can always return the new ones if you don't need them.
Time to create page: 0.168 seconds
