Not Impressed With Suzuki Blue Antifreeze
- auchenblae
- Elite Member
- Thank you received: 25
12 Mar 2025 23:05 #259775
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Not Impressed With Suzuki Blue Antifreeze was created by auchenblae
Untill recently we ran a Mazda Mx5, a Subaru Impreza and a 2016 Jimny SZ3.
The second Mazda MX5 a 2008 model was sold in 2018. The antifreeze was 10years old and I changed it before handing it on via a private sale. The car had done 50,000miles.
There was no rust snowing on the coolant and the colour was still bright green. Mazda advise to change the antifreeze at 5 years for subsequent changes. The antifreeze when changed the second time at 5 years in 2023 old was showing bright green with no sign of rust in the system.
The Mazda MX5 that replaced it in 2018, now 6 years or so old has the original antifreeze still bright green with no rust showing.
With regards to our 2016 Jimny the antifreeze was changed at 8 years old as advised by the Suzuki maintenance schedule. At the seven year service the antifreeze was still bright blue with no signs of rust.
When I changed the Suzuki antifreeze at 8 years old 40,450 miles it was brown and with obvious rust in the liquid. I flushed the cooling system and put in a red antifreeze. When we sold the Jimny three months later the coolant was redish but with obvious rust in the system.
I was less than impressed with the Suzuki blue antifreeze.
We have replaced the Jimny with a new Suzuki Swift Ultimate Allgrip. It has the Suzuki Blue Antifreeze in the cooling system. I will get it serviced by the Suzuki Dealer to get the 7 year warranty now offered by Suzuki. I will have the blue antifeeze replaced at 5 years with the Suzuki blue antifreeze in order to keep the warranty valid but also to protect the cooling system for the next owner.
The Subaru Impreza at 10 years old had the original antifreeze changed at 54,500 still bright green and no sign of rust in the system. When it was sold in 2024 the antifreeze was still bright green with no signs of rust in the system
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
13 Mar 2025 01:40 #259776
by fordem
Replied by fordem on topic Not Impressed With Suzuki Blue Antifreeze
I'm curious - how do you get rust in the cooling system on an "all aluminium" engine?
The cylinder head & block are aluminium, the radiator core is aluminium, where's the iron or steel?
13 Mar 2025 07:52 #259782
Replied by yakuza on topic Not Impressed With Suzuki Blue Antifreeze
Could be remnence of the blue not mixing well with the red?
They do not mix and are incompatible.
- auchenblae
- Elite Member
13 Mar 2025 10:44 - 13 Mar 2025 10:47 #259784
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Not Impressed With Suzuki Blue Antifreeze
I have no idea
fordem,
but it was definitely our good friend iron oxide in the original coolant at eight years old.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Last edit: 13 Mar 2025 10:47 by auchenblae.
- auchenblae
- Elite Member
13 Mar 2025 10:59 #259785
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Original coolant drained, refiled with water and run to thermostat opened and topped up.
Then the for a 4 mile run.
Same again twice, therfore completed three flushes. No visable traces of anything other than water in the drained coolant. In all three cases the heater working to spec and heating the passenger cabin.
Therefore, I cannot work out where there was any old antifreeze to mix with the new antifreeze. As the coolant on the third flush was crystal clear.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
13 Mar 2025 11:08 #259786
by facade
I've not had the head off a twin cam, but I expect that the iron cylinder liners are exposed directly to coolant somewhere too.
Replied by facade on topic Not Impressed With Suzuki Blue Antifreeze
The waterpump rotor, there is also a steel pipe (that rusts from the outside- guess how I know) under the alternator.I'm curious - how do you get rust in the cooling system on an "all aluminium" engine?
Time to create page: 0.281 seconds
