Tracking an Oil Leak - Not the pan or rocker
- Island_Jimny
- Thank you received: 1
09 Mar 2025 20:31 #259733
by Island_Jimny
Tracking an Oil Leak - Not the pan or rocker was created by Island_Jimny
Hi everyone,
I purchased my 2001 Jimny soft top last month and I love it.
Working on it has been a dream but I'm having trouble locating an oil leak, I have yet to clean the whole engine but I was wondering if there were any pointers from the forum first.
As I said in the subject, I have changed the rocker gasket and put in an aftermarket sump gasket. I have also taken a look at the crank and cam seals while changing the timing belt which look ok (a little oil but not a leak).
From what I can tell its coming from the bottom front of the engine. Most of the gunk has built up between the oil and power steering pump.
Its a relatively slow leak but id rather fix it if I can.
Many thanks
Sam
Many thanks
Sam
09 Mar 2025 21:17 #259736
by fordem
Replied by fordem on topic Tracking an Oil Leak - Not the pan or rocker
As far as I'm concerned, step one in finding an oil leak IS to clean everything up - it make it a lot easier to find the leak.
As far as it coming from the bottom of the engine, remember gravity pulls things downwards.
You said you were changing the timing belt, so you have the G13bb motor, apart from the cam & crank seals on the front of the motor there's not a lot in that corner to leak - there are a couple of oil gallery plugs which generally don't give trouble and the oil pressure switch which is a distinct possibility.
- Island_Jimny
10 Mar 2025 09:11 #259739
by Island_Jimny
Replied by Island_Jimny on topic Tracking an Oil Leak - Not the pan or rocker
Thanks, I will locate and take a look at the switch.
Can the oil pump be problematic or is that unlikely?
10 Mar 2025 12:38 #259742
by fordem
The oil pumps rarely give trouble.
- Island_Jimny
10 Mar 2025 18:56 #259750
by Island_Jimny
Bril, I will give it a good clean and post what I find
11 Mar 2025 14:47 #259760
Replied by mlines on topic Tracking an Oil Leak - Not the pan or rocker
Bear in mind that the sump pan does not have a gasket as standard, it just uses sealant.
Be prepared that the aftermarket gasket may not have cured the leak
Time to create page: 0.172 seconds
