2008 Suzuki Jimny JLX Coolant
09 Mar 2025 12:31 #259731 by fordem
A coolant change only gets out about 2/3 of the old coolant, so you need to do it at least twice to get a good effect (replacement of the anti-corrosive components).
Properly done a coolant change WILL get 100% of the old coolant out.  If you're only getting 2/3, the system is not being flushed and you can run into issues because if the old & new coolants are not of the same type.  Typically there is coolant left in the block & heater circuit, this can be removed by flushing with water.
Drain the coolant and refill with plain water, run the engine until it's warm enough to open the thermostat and circulate the coolant, then drain, refill & repeat until there is no trace of the old coolant.  Add half the cooling system capacity of concentrated coolant (not the 50:50 premix/ready to use) and then top up with plain water - this will get you to the 50:50 mix without needing to know how much coolant is left in the block after draining.
10 Mar 2025 06:46 #259737 by AreasGrey
Thank you for all the suggestions!
I did a little investigating and found that they had given some mix-matched information about the coolant used in the service, like "long-life Green" but I found in the paperwork on a different page they had put a parts number next to "long life coolant" and when I did a search for that I found the ECstar "super life Blue". I went and had a look at what's in the reservoir and compared with pictures of the green version I'd seen online and it's definitely the blue one they've used. Found a supplier online and ordered some so problem solved!
Thanks again for all the help.
10 Mar 2025 07:59 #259738 by LM42
Replied by LM42 on topic 2008 Suzuki Jimny JLX Coolant
On our 5 jims, we use the pink long life coolant from ecp, and a proper flush
16 Mar 2025 06:17 #259822 by Hughes
Please FIX THE RADIATOR LEAK!!!
If you accidentally let it get low or if the leak suddenly gets worse when you are driving it, ( this happened to me) it WILL overheat as the temp gauge is little more than a guide. If the temp gauge goes into the red on a Jimny it's basically too late.
Overheating in a Jimny WILL WARP THE HEAD and in my case the block needed skimming as well.
Mine happened to overheat far enough away from civilization (about 30mins drive from my house) that the only option was to follow the river back and refill the radiator from that periodically.
Unfortunately running it for a while with a compromised head gasket eroded between cylinders and I had to remove the engine and get it machined.
Sorry if this comes across a bit aggressive but I would hate for you to have to go through the pain and expense of damaging the engine.
