Transfer chain not fitting low range gears from Trail Gear kit
15 Mar 2025 16:43 #259811 by JimnyCol
Finished and closed the transfer, mounted, but testing it is awful until now, very noisy sometimes. Especially when starting 1st gear or reversing.
Colombia: 2017 Jimny JB43, M13A 163,000 km, +4 cm XT suspension lift, TTS rear air diff locker, Easy Traction manual transfer shifter, AISIN free wheel manual hubs, WARN 55-S winch
15 Mar 2025 19:01 #259815 by Lambert
What kind of noise, reduction gears are notorious for a lot more whining.
16 Mar 2025 10:50 #259824 by jackonlyjack
I completely agree with Lambert
I have sj box with trailgear gears reverse and 1st are very whining
I just change oil regularly
16 Mar 2025 22:43 - 16 Mar 2025 22:49 #259830 by yakuza
There is an awful whine and grind the frist 1000km then gradually less but never goes away completely. I would change the Oil before 1000km and then before 5000. And it Will look terrible with metal powder and shavings.
This comes from the new gears that is not profile ground to shape and must be run in. Terrible but normal.
Also your New gears are at less helix angle to take more ratio without adding too much thrust force inside the gearbox wich add noise.
With less angled teeth there is less overlap from one tooth to the next making more noise.
Will get better. After running in.
Last edit: 16 Mar 2025 22:49 by yakuza.
Time to create page: 0.225 seconds
