Massive MOT failure - is it worth saving
05 Feb 2025 08:03 #259358 by Forde
It's a shame I'm so far away from you (far south west Cornwall) as I'd really like to use someone who knows Jimnys. I rate my local garage but they're definitely not Jimny specialists
05 Feb 2025 08:22 #259359 by Rogerzilla
The ABS light can just be due to LED brake bulbs.  These usually trigger an intermittent ABS fault unless they have the right inbuilt resistors.  Put normal bulbs back in and it's fixed.
05 Feb 2025 08:41 - 05 Feb 2025 08:45 #259360 by Forde
I believe the ABS has been completely disconnected but not 100% sure on that
Last edit: 05 Feb 2025 08:45 by Forde.
05 Feb 2025 09:49 #259361 by Lambert
With the one exception of the arb mount it's all just mechanical and therefore relatively straight forward, I'd be rather more concerned if it needed a lot of welding as that's beyond most people to do properly. Sticking with it is the future.
The following user(s) said Thank You: Forde
05 Feb 2025 09:53 #259362 by Forde
Thanks for that, again making me feel a bit better. My local garage don't seem at all phased by the welding side of things.
05 Feb 2025 15:43 #259368 by Lambert
Probably not but there's mot welding and there's repair/restoration welding, they are not the same.
Time to create page: 0.224 seconds
