Welding around front headlamp area
- Sirjamesrusty
Topic Author
- Junior Member
- Thank you received: 1
22 Jan 2025 11:48 #259178
by Sirjamesrusty
I'm starting my Jimny experience as a complete novice on a 2008 Jimny VVTS...
Welding around front headlamp area was created by Sirjamesrusty
Morning - I'm looking at trying to get an idea of cost and time attached to cutting out corrosion and creating new areas at the front end of my Gen 3 in order to preserve it. I'd like to get the car up to a better level but not sure how much work is involved in doing this. I will share some pictures later today. Have others embarked on this part of the car as it's a common area for corrosion. Thanks 👍
- Thank you received: 1999
22 Jan 2025 18:21 #259180
Replied by Lambert on topic Welding around front headlamp area
As has been said before it depends on how useful you are with a welder vs paying someone else to do it for you, and how particular you are with regards to the finished product?
The following user(s) said Thank You: Sirjamesrusty
- Darthblaker7474
- Elite Member
- Thank you received: 37
22 Jan 2025 20:49 #259182
by Darthblaker7474
Replied by Darthblaker7474 on topic Welding around front headlamp area
Depends on the level of corrosion, you could be just as well off replacing the entire slam panel (about £400 for the part) in the time you've taken to weld in patches.
- Sirjamesrusty
Topic Author
- Junior Member
22 Jan 2025 22:38 #259185
by Sirjamesrusty
Replied by Sirjamesrusty on topic Welding around front headlamp area
What is the slam panel - is that just replacing the whole front end that's attached to the rest of the car. I did see you could get these at one point or would you get a good one from another Jimny for example? Thanks. Daylight failed me today so couldn't take pics.
- Sirjamesrusty
Topic Author
- Junior Member
22 Jan 2025 22:58 #259186
by Sirjamesrusty
Sorry I've googled this now so get what you mean. Sounds like a potential good idea - will check where the corrosion is all got to tommorow. Thanks.
- Darthblaker7474
- Elite Member
26 Mar 2025 22:17 #259930
by Darthblaker7474
Yeah you can take one off another Jimny, however it might me just as rusty!
Time to create page: 0.528 seconds
