What do you call this part?
18 Jan 2025 05:13 #259120
by vinpoldo
What do you call this part? was created by vinpoldo
When I was about to the an oil change, I saw this tear on some sort of hose or tube. Can somebody help me identify what this is?
- Thank you received: 679
18 Jan 2025 09:36 #259123
Replied by DrRobin on topic What do you call this part?
Someone else might know better than me but I think it’s the high pressure fuel line to the injectors, although it might be a vacuum line.
The damage looks like it has been caused by a mouse or rat chewing the hose, either way it needs replacing and a way of discouraging the rodent in case of future attacks.
18 Jan 2025 12:41 #259127
by fordem
Replied by fordem on topic What do you call this part?
That would be "hose, fuel return" - the round object it's attached to on the left end is the fuel pressure regulator, and that is bolted to the fuel rail that feeds the injectors.
Here's how the system works, the fuel pump supplies fuel under pressure to the rail and through it to the injectors, the regulator is at the end of the rail and allows "excess fuel" to return to the tank through that hose.
It can be replaced with hose of the correct diameter as long as it is rated for petrol, it's not a high pressure hose.
Suzuki supplies it as "bulk hose" that you then cut to the correct length,
The following user(s) said Thank You: vinpoldo
Time to create page: 0.157 seconds
