Gen 3 battery draining
- Atomsmasher
- Thank you received: 1
01 Jan 2025 14:57 #258923
by Atomsmasher
Replied by Atomsmasher on topic Gen 3 battery draining
Thank you for your reply Motacilla - this very helpful advice indeed. I will have a close look at the weekend. Much obliged, Mark.
- Thank you received: 662
01 Jan 2025 18:16 #258926
Replied by DrRobin on topic Gen 3 battery draining
According to the information I have the 50A fuse in the main fuse box, in the engine compartment is associated with the ABS. However, if the current changes on this fuse when opening the doors that doesn’t sound right.
If it is a lighting fuse, it most likely feeds the second fuse box under the dash on the drivers side. Pulling some of these fuses might narrow the problem down.
With the keys out and especially locked most circuits are switched off so a large current draw is unusual.
One other problem, mice sometimes get in and chew the cables, is there any evidence of rodent activity?
Robin
Robin
- Atomsmasher
02 Jan 2025 11:19 #258937
by Atomsmasher
Hello again Robin. Thank you for the follow-up. Your post made me question my information. It turns out I was working from an inaccurate description of the engine compartment fuse box. The 50A fuse in question is actually the 'passenger compartment fuse box fuse', not the lighting ring fuse. So all I have to do now is pull each fuse in the passenger compartment fuse box until the current draw drops significantly, then I will know which circuit is the cause. I won't get a chance to look at this for a couple of days. I'll report back. Many thanks.
The following user(s) said Thank You: DrRobin
02 Jan 2025 16:02 #258943
There aren't many circuits which are left live with the keys out and locked.
Clearly the remote central locking is one, as are the door lights and you might find the brake light can be active.
Robin
Pulling fuses
Robin
Pulling fuses
- Rogerzilla
- Premium Member
- Thank you received: 15
03 Jan 2025 08:32 - 03 Jan 2025 08:33 #258958
by Rogerzilla
Replied by Rogerzilla on topic Gen 3 battery draining
You could fit a Discarnect for £10. A little inconvenient to use every day and you will lose the time and trip meter settings (in your case, you would not use the bypass fuse option), but it will stop the battery draining while you investigate the cause, and is useful in future as a security feature.
Last edit: 03 Jan 2025 08:33 by Rogerzilla.
- Atomsmasher
10 Jan 2025 09:36 #259044
by Atomsmasher
Thank you one and all for your helpful suggestions. I finally found an opportunity to pull some cabin fuses. When I removed the radio fuse, the current draw disappeared. Unfortunately, it also appears to have disabled the central locking. Rather than burden the forum with more problems, I am going to take the car to a dedicated auto electrician and see if he can make sense of it all. Thank you all for your time and consideration.
Time to create page: 0.249 seconds
