Gen 3 battery draining
- Atomsmasher
- Thank you received: 1
31 Dec 2024 21:55 - 31 Dec 2024 21:56 #258917
by Atomsmasher
Gen 3 battery draining was created by Atomsmasher
I have a 2013 Jimny with a new battery. Following a charge to 100%, the battery is running flat after about 10 days whilst parked and not in use. There is a 420mA current being drawn in the lighting circuit when the key is out and the doors are closed. All the lights are working correctly and off during the current measurement. Suspecting a faulty brake-light switch, I tried removing the fuse for the brake lights, but the current draw is the same. Does anyone have a circuit / wiring diagram for a generation 3 or any suggestions about where to look next? Does any other electrical system draw power from the light ring? Thank you in advance.
Last edit: 31 Dec 2024 21:56 by Atomsmasher.
- Thank you received: 678
31 Dec 2024 22:49 #258918
Replied by DrRobin on topic Gen 3 battery draining
Do you have an aftermarket stereo, alarm, tracker or other device fitted? Aftermarket stereos are often the cause
How do you know it’s in the lighting circuit? Did you put a current meter in place of the fuse or in the battery lead? Was the door open at the time?
Sub 50mA is more typical, but an aftermarket stereo, alarm or tracker can easily draw this amount of current.
Robin
Robin
- Thank you received: 2005
01 Jan 2025 04:39 #258919
Replied by Lambert on topic Gen 3 battery draining
Does it have a trailer socket or the remnants of such probably behind the rear passenger trim in the inner wheel skin?
01 Jan 2025 06:39 #258920
by Motacilla
A relay can fail in such a way that it becomes a constant power drain, effectively a resistor. This is not uncommon after years of service, particularly if the relay is exposed to damp. One way to check for a short is to disconnect each relay one by one while monitoring the draw at the battery.
Good luck!
Replied by Motacilla on topic Gen 3 battery draining
I think Lambert is on to something. Trailer wiring is more exposed and prone to damage than most car circuits, and it has relays as well.Does it have a trailer socket or the remnants of such probably behind the rear passenger trim in the inner wheel skin?
Good luck!
- Atomsmasher
01 Jan 2025 14:54 #258921
by Atomsmasher
Replied by Atomsmasher on topic Gen 3 battery draining
Hello Robin,
Thank you for your reply - it is greatly appreciated. The 50A lighting fuse was removed from the fuse box in the engine compartment and a current measured with a meter inserted in series, whilst the doors were closed. The car doesn't have any aftermarket additions, but I do not know its full history. When the doors were opened, the current draw rose to 950mA, but the cabin light did not illuminate. I will take a close look at the radio as you have suggested. Something on the light-ring is the culprit.
Thanks again.
Kind regards, Mark.
Thanks again.
Kind regards, Mark.
- Atomsmasher
01 Jan 2025 14:55 #258922
by Atomsmasher
Thank you for your suggestion Lambert - in all honesty, I do not know. I will take a look when I next get a chance. Much obliged.
Time to create page: 0.176 seconds
