Headlight load level adjuster motors
1 year 11 months ago #258548
Headlight load level adjuster motors was created by mlines
Does anyone know how to remove the level adjuster motors from the Jimny headlights??
The instructions with the headlight are unreadable, they have been photocopied too many times and the pictures are simply black
The first two pictures show the motor in place on the old headlamps
This shows the new headlamp perhaps with either a blanking plug or part of the mechanism in place??
1 year 11 months ago #258549
Replied by Soeley on topic Headlight load level adjuster motors
Does the blanking plug on the new headlight come out or is that stuck fast also?
Can you see anything from the bulb aperture with small inspection mirror or endoscope?
Failing that have you tried twisting the motor body to see if it is held in on a bayonet fixing?
1 year 11 months ago #258550
Replied by mlines on topic Headlight load level adjuster motors
Thanks, that has moved things along a bit. Having soaked them in releasing fluid the whole motor case can be turned 1/4 turn and then springs up (out) about 8mm. This is the same for the "blanking plug" - but then none of them come out any further. At this point the headlamp bulb mounting ring moves about if you wobble the motor so there is some further "release" needed
1 year 11 months ago #258553
1 year 11 months ago #258554
Looking at step 2, does an 8mm socket fit the Hex on the blanking cap?
1 year 11 months ago - 1 year 11 months ago #258555
Hi,
No it doesnt fit the blanking plug as that is 13mm hex head. However, using a 13mm on the blanking plug reveals it unwinds a long thread.
Then looking on top of the motors there is an 8mm hex head which then unwinds a similar long thread and the motor comes out.
This means the blanking plug is not a blanking plug, its a manual adjuster that you can remove and replace with the motor version. The motor winds up and down the long thread to adjust the headlight.
So that is good news because if the motors do not work (they have never worked since I got the car in 2007) then I now have a manual adjuster to use.
Thanks for your thoughts, I now think this whole process is worth a new video!
In the picture the "blanking plug" manual adjuster is on the left and the now extracted motors are on the right. I know how the motors work (switched resistor bank) so I can play with getting them going.
Last edit: 1 year 11 months ago by mlines.
Time to create page: 0.103 seconds
