Wobbly Gear Stick
02 Jan 2025 21:14 #258949 by Darthblaker7474
Replied by Darthblaker7474 on topic Wobbly Gear Stick
No problem!
This was from when I replaced it on mine, the difference was night and day.
I do wonder if there's any performance companies that make stiffer bushings that can take up more of the slop in the gearbox.
03 Nov 2025 19:18 #262584 by mikey7985
Replied by mikey7985 on topic Wobbly Gear Stick
Hi Darth could you tell me if it’s easy to get the gear stick out like this please? I need to change that white bush on the end apparently.
Thanks,
Mike
05 Nov 2025 20:41 #262630 by Darthblaker7474
Yeah it was easy enough, remove the surround, gaiter, then unbolt (10mm?) the bracket that holds the secondary gaiter.
Then it's two more bolts (10mm?) either side of the gear stick to get the shaft out.
make sure you refit the secondary gaiter properly so it seals. Mine wasn't and after doing so the cabin noise dropped significantly.
The following user(s) said Thank You: Filipao
