4wd 4l overheating
- Thank you received: 590
16 Nov 2024 22:06 - 16 Nov 2024 22:06 #258347
Replied by DrRobin on topic 4wd 4l overheating
What you have described is not normal.
What was the outside temperature, your car shows this on the dash board?
How long were you driving up this muddy hill?
Was the engine temperature normal before you started on the muddy hill?
Last edit: 16 Nov 2024 22:06 by DrRobin.
- Thank you received: 1908
16 Nov 2024 23:11 #258348
Replied by Lambert on topic 4wd 4l overheating
As said above this is not normal. By virtue of steam/ smoke/ vapour coming from the engine bay you have obviously done something that has stressed the engine/put it under too much load for too long. I strongly suggest you have it properly investigated by a suitably qualified garage be that the main dealer or other specialist in jimny local to you. It's not simply going to get better by itself. You need someone to confirm that you don't have exhaust gasses in your coolant and that it has correct compression on all cylinder as a minimum check on the engine health. You might be lucky but I wouldn't count on it, you could just as easy hurt it quite badly.
- The Coil Spring
- Junior Member
- Thank you received: 3
17 Nov 2024 01:22 #258350
by The Coil Spring
Replied by The Coil Spring on topic 4wd 4l overheating
To me your description of events sound like the cooling fan isn't coming on when it should. Have you checked it?
17 Nov 2024 09:35 #258351
by Motacilla
Yes, you quite possibly damaged your engine and it needs to be checked by a professional. They have tools and experience that you do not have, and we can't help you with.
No, there is nothing you can easily check "to see that there was no damage." Boiling and/or exhaust-contaminated coolant is already a sign that there was potentially damage to one or more components.
Your choice is: go immediately to the professional shop to get it fixed, or don't. If you choose the latter, you might save money in the short term, but will almost certainly spend more in the long term.
Good luck to you
Replied by Motacilla on topic 4wd 4l overheating
Nickcot, maybe this answer will help.is there something i can do to see if there was any damage? how can i check the 4l 4wd transmission and whatsover to see that there was no damage to the engine or so
Good luck to you
- Rogerzilla
- Premium Member
- Thank you received: 15
17 Nov 2024 09:37 #258352
by Rogerzilla
Replied by Rogerzilla on topic 4wd 4l overheating
The gen4 has an electric fan so this is a possibility. Could also be a stuck thermostat but they usually last > 10 years easily.
When you say the temperature was red, did you get a red warning light? I don't think the gen4 ever has a proper gauge.
- The Coil Spring
- Junior Member
17 Nov 2024 11:51 #258353
by The Coil Spring
It is correct that the gen 4 doesn't have a gauge, disappointingly. Instead there is a warning light that looks like this:When you say the temperature was red, did you get a red warning light? I don't think the gen4 ever has a proper gauge.
Time to create page: 0.499 seconds
