Gen 3 rear ABS Sensor wires clips
08 Nov 2024 19:19 #258231 by auchenblae
2016 car with ABS, the sensor wires from the rear ABS sensors are clipped to the rear radius arms. The arms have M6 threaded holes and an M6 bolt holds on each cable clip to the radius arm. The clips come attached to the sensor wires. I need a total of say 6. They are not available from Suzuki on their own.
I just used plastic cable ties and it passed the MOT with no advisories last week but I would like to put on clips on each existing M6 bolt as a "proper job".
I'm worried that if I made up metal tabs, they may dig into the ABS sensor wires. I was thinking of say 15 mm wide rubber strips with a 6mm hole in each end to fix the cables to the radius arms, has anyone a better suggestion.
eddie
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
09 Nov 2024 05:46 #258237 by Lambert
You can get metal clips with rubber isolation built in off amazon for pence or indeed full plastic ones too just search P clips.
09 Nov 2024 13:03 #258241 by auchenblae
You are a star indeed, exactly what I was looking for!
Thanks
Eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.337 seconds
