Changing the ATF
- Rogerzilla
- Premium Member
- Thank you received: 15
28 Oct 2024 17:16 #258078
by Rogerzilla
Changing the ATF was created by Rogerzilla
Has anyone used one of the specialists that have a machine to flush out the slushbox and renew the fluid? Any recommendations near either Ludlow or Swindon (we're moving house at some indeterminate point in the next 3 months)?
- Thank you received: 2005
28 Oct 2024 18:30 #258079
Replied by Lambert on topic Changing the ATF
Unless you need need to the general consensus is to leave it alone. Is it brown or smells of toast?
- Rogerzilla
- Premium Member
29 Oct 2024 08:33 - 29 Oct 2024 08:39 #258088
by Rogerzilla
Replied by Rogerzilla on topic Changing the ATF
I thought the consensus was to change it before it got bad, but not to change it once it HAS gone bad (as the crud in the fluid helps worn-out clutches get a grip - changing the fluid too late can result in a non-working box).
The car has done 53,000 miles over nearly 13 years. The fluid is still a nice red and the box works as it should.
Last edit: 29 Oct 2024 08:39 by Rogerzilla.
29 Oct 2024 11:06 #258091
I'm mostly going on what I was told by my 2 local suzuki dealership service departments, whom were both being offered the job?
29 Oct 2024 11:08 #258092
Also I seem to remember that service book says 90k or something.
Time to create page: 0.154 seconds
