Wipers coming on with lights
15 Oct 2024 19:50 #257892
by Busta
Wipers coming on with lights was created by Busta
I've been putting a Jimny back together after doing a fair bit of work on it (welding, head gasket, clutch). I now have an issue whereby when I turn the lights on the front and rear wipers also come on. If the lights are off the wipers work as normal. Has anyone experienced this before? Any clues where to start looking?
- Thank you received: 679
15 Oct 2024 20:29 #257893
Replied by DrRobin on topic Wipers coming on with lights
Strange electrical faults like this are often a bad or missing earth and the current drawn by one device finds another path. However, I doubt there would be enough voltage/current through the light to also turn the rear wiper.
Do the rear lights (or the front) work when switched on?
I know the headlights are negative switched, but not sure about the rear lights or rear wiper, they might both be positive switched.
Hope that helps.
Robin
Hope that helps.
Robin
16 Oct 2024 12:13 #257906
by Busta
Replied by Busta on topic Wipers coming on with lights
The lights are working correctly. With the ignition off the lights come on as normal with no wipers. When I turn the lights on with the ignition on I hear a click from a relay under the dash and the wipers start. With the lights off the wipers work as normal. So maybe it's a relay somewhere. I shall have to consult the wiring diagram and see if there's anywhere obvious where the 2 circuits meet.
16 Oct 2024 14:34 #257910
by facade
Replied by facade on topic Wipers coming on with lights
The relay will be the intermittent wiper circuit.
I'd look for trapped/misplaced/shorting wires going to the column switches. There is a rather complicated wiring arrangement to the column switches for the wipers to change speed, run intermittent and even self-park.
17 Oct 2024 19:18 #257939
by Busta
Good news and bad news. The bad news is I haven't found the cause of the problem. The good news is it has fixed itself. The car has been sat for almost a year and after a 15 minute drive today it's back to working as it should.
Time to create page: 0.110 seconds
