Headlight level adjust not working
25 Sep 2024 09:12 #257677 by PDX-ORE
Blown fuse?
From what I can tell, the whole lamp (headlight, signal, running light, leveling motor) are all on one fuse. It does not have an independent fuse for just the leveling motor.
_________
Greetings from Portugal
25 Sep 2024 09:34 #257678 by facade
They are actually a little position servo, like in an RC aeroplane etc.
The roller on the dash is a potentiometer that sets a voltage, and the headlamp motor winds a leadscrew in or out until the potentiometer attached to the light gives the same voltage. After a few years, dirt/wear on the potentiometer track at the headlight end causes it to continually hunt back & forth with a sort of high pitched zzzzzzz noise that will drive you nuts trying to find it, but a slight tweak of the roller on the dash will sort it.
They run continually with the ignition IIRC, which is why the noise is so annoying & hard to find, as the lights aren't necessarily on so you don't think it is them.
The whole light doesn't move, just the reflector inside it.
Anyway, as Martin said, could be seized motors, or sometimes the leadscrew gets disconnected inside the headlight and the motor runs straight to one end of its travel and stops trying to get the voltages to match.
25 Sep 2024 14:19 - 25 Sep 2024 14:23 #257681 by fordem
Blown fuse?
I don't know where you're getting this idea from, but it's incorrect, headlights are on two fuses (left & right are fused separately), turn signals are on a different fuse, running lights on another fuse - I've never looked to see where the level motor gets it's power from, but, we're upto a count of four fuses so far, not just one.
Last edit: 25 Sep 2024 14:23 by fordem. Reason: typo
25 Sep 2024 14:20 #257682 by fordem
I took a quick look at the diagrams - headlight levelling gets power from the wiper/washer fuse ...
The following user(s) said Thank You: facade, Motacilla, PDX-ORE
25 Sep 2024 18:55 #257684 by PDX-ORE
Interesting. The wipers/washer systems are working fine. But great to know!
I do not have the Service/Workshop manual yet, so need to get my hand on one. Was assuming the beams/turns were on the same fuse as my box-lid does not label them individually.
Appreciated!
_________
25 Sep 2024 19:24 #257685 by facade
That explains why mine made that noise whenever the ignition was on.
Time to create page: 0.096 seconds
