Difficulty changing gears
18 Sep 2024 16:49 - 18 Sep 2024 16:53 #257571
by Vandoni
Difficulty changing gears was created by Vandoni
I have problems changing gears, even when stationary, if the engine is on, if i put it in 1st and then neutral, it is hard to put it back in gear again, that doesn't happen with the engine off.
Also while moving, changing gears is super hard, even while rev-matching and being careful.
Sometimes the transmission remembers that it's supposed to work and everything goes back to normal, only to revert back to being "broken" again in a few shifts.
I also tried removing the shift lever like it said in some other post on this forum, and from the hole came a slightly burnt smell.
Last edit: 18 Sep 2024 16:53 by Vandoni.
- Thank you received: 2005
18 Sep 2024 17:26 #257573
Replied by Lambert on topic Difficulty changing gears
It's possible that someone has changed the oil in the box. If they have used either a pure gl5 or a gl4/5 combination oil it is wrong. It needs to be a pure gl4 as there are yellow metal parts in the box that don't play well with the gl5. I made this mistake for a couple of months and flushed it out without any longer term effects.
18 Sep 2024 17:38 #257575
by Vandoni
Replied by Vandoni on topic Difficulty changing gears
i don't really know what kind of oil is in there, i'll have it changed while i get the nylon ring replaced, cause i read in another thread that there should be a white nylon something under the shifter lever, and when i checked today, there was nothing.
- Thank you received: 676
18 Sep 2024 23:06 #257579
Replied by DrRobin on topic Difficulty changing gears
Difficulty changing gear is usually a clutch not disengaging correctly. It could be the cable, the thrust bearing or a sticking clutch.
Is the clutch working correct or does the pedal have to be pushed to the floor before it disengages? You might be lucky and it might just need adjusting.
Robin
Robin
19 Sep 2024 01:26 - 19 Sep 2024 01:28 #257581
by Vandoni
I'm starting to think it's the clutch too, (because the gears don't act stupid when the engine is off.
The clutch was changed 4 months ago, the pedal is pretty soft, but it's always been that way. I wanted to try and tighten the cable, but I'm a big guy and the space under the steering wheel is pretty limited
, also I don't really know how to do that
Last edit: 19 Sep 2024 01:28 by Vandoni.
19 Sep 2024 04:47 #257582
There's a big plastic nut thing at the gearbox end of the cable for adjustment.
Time to create page: 0.166 seconds
