Is there a difference between the radius arm protectors ? recommended one ?
03 Sep 2024 02:38 #257406 by Chicken
Hi,
Just looking at options to protect a brand new Jimny.  One of the options that keeps coming up is radius arm protectors, being the lowest part of the underbody seems like a sensible upgrade.
However is there a recommended brand ?   Are they all pretty much the same ?
Am getting a rust proofing done before receive the car from new as hoping this will be a long term car so just looking for the best options to protect the investment.
thanks.
03 Sep 2024 06:37 - 03 Sep 2024 06:38 #257407 by Soeley
I have the Jimnybits protectors. They do not require any drilling to fit them. Some brands require a hole drilling through the side of the radius arm bracket, I think this Is to prevent the trailing edge of the protector from drooping, so it doesn't snag if you are reversing over an obstacle. Other brands achieve this by having a longer protector with a little tab at the end that locates in a existing hole in the chassis.
The Jimnybits protectors are such a snug fit, neither of the above locating methods are required.
I would personally (and did) go for an option that doesn't require drilling any holes.
Last edit: 03 Sep 2024 06:38 by Soeley.
03 Sep 2024 06:40 #257408 by Chicken
t6hanks for your input, yeah I dont want to drill holes really. Are these easy to fit or is it better to have them fitted in case any alignment requires checking after fitting ? Im no mechanic so have never fitted anything other than non essential parts like replacing wingmirrors to cars before ;)
03 Sep 2024 07:05 #257410 by Gadget
Jimnybits ones here too, chosen as they were the only readily available option at the time!
They're dead easy to fit - if you're slim you don't even need to jack the car up. Just position a jack under the arm you're working on to stop it from moving, undo the existing bolt, hold protector in place and fit new extended bolt and spacers, torque to spec, done.
LIke all JB stuff they're made of very thick steel, so protection is excellent but the powder coating is a bit rubbish, so they'll suffer surface rust once knocked. The metal is so thick that it doesn't really matter from a structural perspective, just cosmetic. I plan to take mine off, sand and repaint as some point to make them pretty again, as I've already had to do with my JB rocksliders.
03 Sep 2024 08:41 #257411 by 300bhpton
Hi,
thanks.
Do you plan to off road and do you have a budget?
As far as I know all of the radius arm protectors are basically the same design. I can’t be certain, but any I’ve seen online are. None of those require drilling.
I also have the Jimnybits ones. They are a good price. Some are very expensive, to which I have no idea how the price can be justified.
If you only want them for looks or won’t be going over rocks there are aluminium ones I believe. They are likely fine, but potentially more easy to bend.
The steel ones do run the risk of rusting. Powerder coating always fails and in use will likely get damaged. But they are not that visible and easy to tidy up with something like Dinitrol.
Fitting is fairly easy. You’ll need a hard standing, a jack and an axle stand. Plus the right sockets/spanners. I found an electric windy gun (impact gun) to be great for this.
The Jimnybits ones have spacers inside the guard that you need to get in place for the bolt to go through. A shame they aren’t welded to the guards. So this can be fiddly. I used some Dinitrol to hold the spacers in place as I carefully lifted the guard into place.
Potentially the radius arm will move a bit, so you might need to be able to roll the tyre & axle forward or back a tad. Having an extra bottle jack is also handy so you can jack up the chassis end of the arm should you need too. However, if you are not removing the arm from the vehicle (new bushes). It may not move at all and make it all easier.
An extra pair of hands can be handy if you do need to move the axle. So one person can look to see when aligned and push the bolt home.
None of this has any impact on wheel or vehicle alignment.
03 Sep 2024 09:36 #257412 by DrRobin
I don't have any protection on my Gen 4 yet, but I am going to do more trials and a few treks planned, so it might be an idea.
I had radius arm protectors on my last Jimny, so these might be a good idea, but what do you think about the following:
- Front Diff
- Transfer Case
- Rear Diff (may be less likely to be needed than the other two?)
Just looking at Jimnybits at the moment, they aren't too expensive.
I am not lifted, so I assume I will loose a little clearance, is that going to be a problem or do the diff/transfer case fit really snug?
I have touched bottom a couple of times, all soft stuff so far and can see a few marks on the front radius arms, but think the front diff touched last week and I don't want to risk the transfer case.
I want the front recovery points as well, but they are out of stock.
Robin
Time to create page: 0.287 seconds
