Obd 2 scanner with abs bleed recommendation
18 Jul 2024 09:18 #256825
by ptransfer
Obd 2 scanner with abs bleed recommendation was created by ptransfer
Hey guys
Just replaced the brake master cyl. and was hoping to bleed the ABS module (my abs light is on as well)
I couldn't find a recent post about OBD2 scan tools. Can anyone give a recommendation that will do the ABS bleed and be generally good. I have an 09 Jimny
Thanks in advance
Thanks in advance
18 Jul 2024 10:43 #256827
by facade
Replied by facade on topic Obd 2 scanner with abs bleed recommendation
According to the manual, you just bleed the wheels in the usual manner and don't worry about the abs unit. There is nothing about using the secret suzuki scan tool to do it.
- Rogerzilla
- Premium Member
- Thank you received: 15
18 Jul 2024 16:42 #256830
by Rogerzilla
Replied by Rogerzilla on topic Obd 2 scanner with abs bleed recommendation
The stuff held up.in the ABS pump will not be drained (it's the other side of the valves), so doesn't need bleeding. Of course, if you replace the ABS pump with a new one, it does need bleeding somehow.
A low-tech way to exchange the pump fluid is to find some gravel or snow off-road and make it do its thing repeatedly.
19 Jul 2024 00:49 - 19 Jul 2024 00:53 #256836
by ptransfer
Replied by ptransfer on topic Obd 2 scanner with abs bleed recommendation
Thanks mate that's good to hear
. I have read about going off road to fix the ABS - ill give that a go tonight.
If that doesn't work to fix the ABS light (it was on before replacing the master cylinder) do I need a scanner to figure out what's going on? I don't mind spending money on a good scanner if it will be useful in the long run - just want to make sure I get a good one!
I've inspected the ABS sensors and they appear okay (not 100% on what to look for - but no apparent cracking/excessive wear/contacts look good).
Last edit: 19 Jul 2024 00:53 by ptransfer. Reason: Needed to add more
- Thank you received: 2005
19 Jul 2024 03:26 #256839
Replied by Lambert on topic Obd 2 scanner with abs bleed recommendation
Sz viewer is able to read the abs you will need a Bluetooth connection and the app on your phone.
