Gen 3 Boot Rust
09 Jul 2024 10:08 - 10 Jul 2024 21:39 #256700
by danjonesy
Gen 3 Boot Rust was created by danjonesy
Hello all!
I bought a suzuki Jimny about 3 months ago - 2002, 90k miles. Runs really well and I absolutely love it. I somewhat recently put in some speakers in the rear where the factory holes go and during the process, you have to remove the rear seats. I used this as an opportunity to check and take a picture of the rust in the boot section. There is a bit of dirt in here (I cleaned it after the photo was taken but forgot to retake a photo before i put it back together) but I wanted to see if anyone has an opinion on the rust spots? The previous owner said that they welded part of the rear of the boot (I assume where the wheel jack goes) but I can see a couple of rust spots near-ish the seatbelt anchors.
What I am trying to deduce is, will this rust cause any problems for safety, and if I need to get the rust spots removed and welded? Or if the rust won’t cause any affect to safety so therefore it isn’t of concern yet?
https:// www.icloud.com/iclouddrive/03bUAoR2PrR4ye2q8y8jOGXyQ#Jimny_Boot
Any opinions would be greatly appreciated
Cheers, Dan
Cheers, Dan
Last edit: 10 Jul 2024 21:39 by danjonesy. Reason: Added photo
09 Jul 2024 15:43 - 09 Jul 2024 15:45 #256701
Replied by yakuza on topic Gen 3 Boot Rust
The picture is not visible.
Might be for Apple users but closed as is now.
Pictures can be up loaded to this site, use the full editor, press attachments, add file, insert.
Hope I can find a better explanation to link here
Last edit: 09 Jul 2024 15:45 by yakuza.
The following user(s) said Thank You: danjonesy
10 Jul 2024 21:40 #256728
by danjonesy
Replied by danjonesy on topic Gen 3 Boot Rust
Hi mate, thank you for letting me know - I’ve attached it using your instructions - let me know what you think if you wouldn’t mind
- Thank you received: 2004
11 Jul 2024 03:25 #256731
Replied by Lambert on topic Gen 3 Boot Rust
It's not the worst I have ever seen but I would be looking at getting it dealt with if it were mine.
- Me and my Jimny
- Premium Member
- Thank you received: 9
11 Jul 2024 05:58 #256734
by Me and my Jimny
Replied by Me and my Jimny on topic Gen 3 Boot Rust
While it's still quite small patches with seemingly good metal around it is the best time to deal with it. Wire wheel on a drill will clean it up and if it doesn't make a hole then you're laughing, just a paint job. If it does then it needs patching
- Thank you received: 679
11 Jul 2024 06:35 #256735
Replied by DrRobin on topic Gen 3 Boot Rust
Treat with a rust inhibitor before painting with ordinary car paint, unless you use a paint with rust inhibitor built in.
They generally rust from the inside, but check the outside as well.
Robin
Robin
Time to create page: 0.118 seconds
