Removal of air con pump pulley
06 Jul 2024 13:44 #256659 by Tinbox1979
Hi guys
my air con pump has seized and the pulley will not move. Is is a straight forward job to remove the pulley.
Thanks
06 Jul 2024 14:21 #256660 by fordem
If you have access to the right tools, it's not difficult, space to work is likely to be the biggest challenge - an impact gun is generally the easiest way to get the clutch off and then there should be a large circlip holding the pulley/bearing assembly.
If it's the compressor that has seized, you should be able to just disconnect the lead to the compressor clutch to stop it from engaging and the pulley should spin freely.
The following user(s) said Thank You: Tinbox1979
06 Jul 2024 14:38 #256661 by Tinbox1979
The pulley is not spinning at all it is solid it jammed whilst I was driving causing the belt to snap. Would removal of the air con compressor be an easier solution as I don’t need air con
06 Jul 2024 15:17 #256665 by Lambert
Alternatively just bypass it with a 4pk850 drive belt and leave the rest in place.
The following user(s) said Thank You: Busta
06 Jul 2024 15:23 #256666 by fordem
Since I don't know what vehicle you're driving, I don't know what else is driven by the same belt, you would have to check and see what is involved in bypassing the a/c pulley, it might be as simple as a shorter belt. If there's no power steering, you might be able to just leave the belt off altogether.
There is usually legislation preventing you from releasing refrigerant into the atmosphere so if the system has gas in it, you'll need to get it recovered before disconnecting the lines.
06 Jul 2024 17:53 #256667 by Busta
2007 Jimny will be M13A so as Lambert says, a 4pk850 belt is all you need.
Time to create page: 0.402 seconds
