Windscreen washers not working (2007)
22 Jun 2024 12:54 #256394 by Forde
Afternoon all. I've been a member for a few months but haven't posted until now. The windscreen washers on my 2007 Jimny stopped working yesterday. The reservoir is full and the pump makes no noise when trying to activate. The wipers still work and I believe they are on the same fuse as the pump. Am I right in my assumption that the pump has probably failed? The rear pump hasn't worked since I bought it a few months ago, so I can't try swapping them over!
Thanks in advance
22 Jun 2024 13:11 #256397 by me101
Hi. Remove the plugs off the pumps, clean and refit. Likely a contact issue.
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
The following user(s) said Thank You: Forde
22 Jun 2024 13:47 #256399 by Forde
Thanks. They don't look too bad but will try that first
22 Jun 2024 14:07 #256400 by Rogerzilla
Cam you check if there is voltage to the pump?  You might need someone to.operate the washers while you hold a multimeter to the electrical connector.
22 Jun 2024 15:15 #256402 by Forde
They actually just worked, albeit very briefly, so hoping cleaning the contacts will work
22 Jun 2024 16:41 #256404 by Lambert
Also be aware that some of the cheaper washer fluid can congeal into slime that blocks the jets
Time to create page: 0.111 seconds
