Windscreen washers not working (2007)
22 Jun 2024 12:54 #256394
by Forde
Windscreen washers not working (2007) was created by Forde
Afternoon all. I've been a member for a few months but haven't posted until now. The windscreen washers on my 2007 Jimny stopped working yesterday. The reservoir is full and the pump makes no noise when trying to activate. The wipers still work and I believe they are on the same fuse as the pump. Am I right in my assumption that the pump has probably failed? The rear pump hasn't worked since I bought it a few months ago, so I can't try swapping them over!
Thanks in advance
Thanks in advance
22 Jun 2024 13:11 #256397
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Windscreen washers not working (2007)
Hi. Remove the plugs off the pumps, clean and refit. Likely a contact issue.
The following user(s) said Thank You: Forde
22 Jun 2024 13:47 #256399
by Forde
Replied by Forde on topic Windscreen washers not working (2007)
Thanks. They don't look too bad but will try that first
- Rogerzilla
- Premium Member
- Thank you received: 15
22 Jun 2024 14:07 #256400
by Rogerzilla
Replied by Rogerzilla on topic Windscreen washers not working (2007)
Cam you check if there is voltage to the pump? You might need someone to.operate the washers while you hold a multimeter to the electrical connector.
22 Jun 2024 15:15 #256402
by Forde
They actually just worked, albeit very briefly, so hoping cleaning the contacts will work
- Thank you received: 2005
22 Jun 2024 16:41 #256404
Replied by Lambert on topic Windscreen washers not working (2007)
Also be aware that some of the cheaper washer fluid can congeal into slime that blocks the jets
