TC & SC question
31 May 2024 04:32 #256139 by SlippinJimny
Hi!
I’ve found a thread about the newer Jimny not allowing you to full disable TC/SC when in RWD mode.
It turns back on when you reach a certain wheel speed.
In that thread they didn’t say if that goes for the older Jimnys (2009 for example) as well, and so I’d like to ask here if it does or not.
Thank you!
31 May 2024 08:08 #256140 by DrRobin
Replied by DrRobin on topic TC & SC question
I am fairly sure that a 2009 Jimny doesn’t have traction or stability control.
Robin
The following user(s) said Thank You: SlippinJimny
31 May 2024 08:11 #256141 by Lambert
Replied by Lambert on topic TC & SC question
I believe that TC only became a thing after the 2013 face lift. Certainly my old 2011 didn't have it but my 16 and 18 both do. It works as stability control in high range by cutting power to reduce relative wheel spin and in low range it works to actively use the abs to force drive across the axle to the none spinning wheel. You can turn it off in either mode but it turns itself on again in high range above 30mph.
31 May 2024 08:34 - 31 May 2024 23:17 #256142 by SlippinJimny
Replied by SlippinJimny on topic TC & SC question
Edit: just googled it and the early ones really didn’t have SC/TC
I feel stupid now, but I never thought that they wouldn’t have any so I googled “how to turn off tc/sc?” instead of “does the early Jimny have tc/sc?”
Thank you for the info! Made my day!
Last edit: 31 May 2024 23:17 by SlippinJimny.
Time to create page: 0.173 seconds
