discs dont fit!
- greenmachine
Topic Author
- Senior Member
- Thank you received: 5
14 Apr 2024 14:02 #255558
by greenmachine
discs dont fit! was created by greenmachine
theres something happening here , theres a disc with my jimny over there, AND it wont go on! center hole too small, says 107mm on spec
but wont go ? arrrgghhh why ! why ! why!
- greenmachine
Topic Author
- Senior Member
14 Apr 2024 14:08 #255559
by greenmachine
Replied by greenmachine on topic discs dont fit!
size . OE: 5521160A00
APEC: DSK943 SDK6193
BLUE PRINT: ADK84305
BORG & BECK: BBD5028
BOSCH: 986478539 0986478539
BREMBO: 8526610 52661 08526610
COMLINE: ADC0902 AND6419
DELPHI: BG2584C BG2584 BG584 BG584C
FEBI BILSTEIN: 10869
FIRST LINE: FBD548
HELLA: 8DD355103611
JURATEK: SUZ104
MINTEX: MDC747
NAPA: PBD8555
QUINTON HAZELL: BDC3779
Notes
Height [mm]: 46
Weight [kg]: 4,4
Brake Disc Type: Solid
Brake Disc Thickness [mm]: 10
Minimum thickness [mm]: 8
Outer diameter [mm]: 289
Number of Holes: 5
Centering Diameter [mm]: 107
Bolt Hole Circle Ø [mm]: 140
FIRST LINE: FBD548
HELLA: 8DD355103611
JURATEK: SUZ104
MINTEX: MDC747
NAPA: PBD8555
Notes
Height [mm]: 46
Weight [kg]: 4,4
Number of Holes: 5
- greenmachine
Topic Author
- Senior Member
14 Apr 2024 14:19 #255560
by greenmachine
108.3mm im guessing! schoolboy/memory error!
Brand New Pair x2 of Suzuki Jimny front brake discs to use on the front or rear (with our rear disc conversion)
The brake discs come in 2 sizes 107mm centre hole and 108.3mm centre holes
Vehicles up to VIN 203804 require 107mm centre discs
Vehicles from VIN 203804 require 108.3 mm centre discs
The VIN number can be found in the logbook, vehicle title paperwork and front windowscreen
Our rear disc conversion kit will accept any disc size
- Thank you received: 678
14 Apr 2024 16:06 #255561
Replied by DrRobin on topic discs dont fit!
Can you send the 107mm discs back and change them for 108.3mm?
Robin
Robin
- greenmachine
Topic Author
- Senior Member
14 Apr 2024 17:21 #255565
by greenmachine
bloody memory!!! yep need the 108.3 Robin! simples! ta m8
14 Apr 2024 22:02 #255567
Replied by yakuza on topic discs dont fit!
When No ABS then d=107
If you got ABS then d=108
At least when ABS is standard..
Emerging markets outside EU or if your car has been ordered with optional ABS then I don't know.
Time to create page: 0.281 seconds
