Loud power steering pump
- Darthblaker7474
Topic Author
- Elite Member
- Thank you received: 37
26 Mar 2024 17:07 #255250
by Darthblaker7474
Loud power steering pump was created by Darthblaker7474
- Thank you received: 2005
27 Mar 2024 09:40 #255255
Replied by Lambert on topic Loud power steering pump
Not wanting to scare you but have you had the gearbox rebuild only noises travel and 08 is prime for bad bearings.
The following user(s) said Thank You: Darthblaker7474
27 Mar 2024 16:53 #255258
by fordem
Replied by fordem on topic Loud power steering pump
Assuming it is the power steering pump, try replacing the fluid as the first step.
27 Mar 2024 18:35 - 27 Mar 2024 18:36 #255260
Replied by yakuza on topic Loud power steering pump
inspecting the fluid should tell you a bit as well. turn the wheel a few times side to side full over. the fluid should be almost clear and not milky, hazy or foam and no particles or too much bubbles..
I had a pump fail on a vw and I went thru most of the above.
Most pump fails will make the pump make more noise when turning.the wheel or you will feel less power from it on the steering wheel.
to listen more presice you could use a piece of broom stick or similar piece of wood to transport and isolate the sound from the part you suspect and up to your ear. or just buy a car stethoscope.
Last edit: 27 Mar 2024 18:36 by yakuza.
28 Mar 2024 17:44 #255277
by facade
Replied by facade on topic Loud power steering pump
When does it make the noise-
All the time the engine is running, moving or not, in neutral and in gear (both when moving and stationary)?
Only when the car is moving?
When stationary, all the time?
When stationary, only when the gearbox is in neutral, stops when it is in gear? (with the clutch full down obviously).
If the answer is "absolutely all the time, neutral or in gear, moving or stationary" and it sounds like it is coming from the power steering pump, slacken the idler pulley and take the power steering belt off. If the noise goes it is either the power steering pump or the idler.
- Darthblaker7474
Topic Author
- Elite Member
28 Mar 2024 18:40 #255280
by Darthblaker7474
Replied by Darthblaker7474 on topic Loud power steering pump
Gearbox has not been rebuilt (yet...) but seems to be running fine albeit a whine in 4th.
I'm assuming I can drive the car to test and see if the noise goes away?
