electric to manual transfer box swap/ help cant use forum!
- greenmachine
Topic Author
- Senior Member
- Thank you received: 5
25 Feb 2024 19:59 #254582
by greenmachine
Replied by greenmachine on topic electric to manual transfer box swap/ help cant use forum!
Cheers Jack, the box my 2005 has in now is from the 2001 Donor is that an R7ME box then from the 2001? the stick/transfer is still in the Donor car.
so it would just swap straight over then eh? but id need a prop shaft and bigger
tall tyres if i did. am i right in thinking that?
26 Feb 2024 19:24 #254614
Replied by jackonlyjack on topic electric to manual transfer box swap/ help cant use forum!
2001 box is R7ME
Just fit the stick transfer
If you can live with engine higher revving then no need to change tyres but taller tyres will bring rpm back down
- greenmachine
Topic Author
- Senior Member
26 Feb 2024 20:42 #254618
by greenmachine
cheers Jack, ill have a crack at that when ive dug into my ecu/immob/no running prob. sounds a good plan,
Time to create page: 0.172 seconds
