electric to manual transfer box swap/ help cant use forum!
23 Feb 2024 22:04 - 24 Feb 2024 04:54 #254534 by greenmachine
Hey up guys, i,m useless on forums and dont know how to use them.   i didnt know last time!   if this is in the wrong place sorry first.
i,m thinking a bit ahead really , as i havent even got her running yet as i only had her transported back today, but i now have her back yippie!!
can someone point me in the right direction for the info on swapping the boxes please?   mines a 55 plate M13A VVT leccy box,  and i have a donor
2001 car , manual transfer box .  is it a staright forward operation?   any help be great ta all.
Last edit: 24 Feb 2024 04:54 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
24 Feb 2024 04:52 #254535 by Lambert
Your first problem is going to be the gearing is going to be way off if you are still on standard 205.70 r15 tyres. There is a plate bolted to the transmission tunnel that when removed allows the lever box to fit. Oh and the bolt holes on the output flanges are different. It's all doable though.
24 Feb 2024 07:57 #254537 by greenmachine
Ar right ok , cheers Lambert.   i did find a chart deep in here showing ratios, when she ran before the eleccy switches only let me down once off road up the back of Whernside above Dent. i was in 4 low and it took some yiggery pokery and a post on here to get sorted , lucky as i was supervising the install of the mobile phone tower at the time, and managed to get a signal from a diff location, i swapped the switches and never had a problem after but it would be a really bad not being able to get the transfer box back into 4 high eh!   It was just the Donor 2001 Jimny has a stick in it and i thought maybe a good idea to swap if i had one.   what would happen? would it be much lower geared?   I think i might leave that area be and concentrate on getting her started first!  thanks again Lambert.
24 Feb 2024 10:34 #254539 by Lambert
You would be going from 1 to 1 high with buttons to 1.3 to 1 with the lever. Ideal if you want bigger tyres but too much really for the standard ones.
24 Feb 2024 17:24 #254550 by greenmachine
roger that Ta lambert. ill leave that be for now then!
24 Feb 2024 19:04 #254559 by jackonlyjack
Most change out the R72 box for an R7ME and stick transfer using intermediate prop from
2001-2004 car
adaptor plates available from various folks
but this means 29" tall tyres would be ideal size
235/75/15-225/75/16
Time to create page: 0.458 seconds
