Replacing ignition lead set
- Thank you received: 679
20 Feb 2024 16:54 #254484
Replied by DrRobin on topic Replacing ignition lead set
£30 - £40 was for the coil pack with one lead moulded in. The lead to the other cylinder is usually not that expensive. Sure, you need two coil packs and two leads for a full set.
Robin
Robin
- Thank you received: 11
21 Feb 2024 20:41 #254503
by JAGtheman
Julian
2008 Gen 3 Manual
Being completely revitalised
Replied by JAGtheman on topic Replacing ignition lead set
I bought a Ridex ignition cable set (4 cables) for GBP15 and 2 x Hella ignition coils for GBP48 (Total GBP63). I could get cheaper, but I did not recognise any names and I felt this is a once off purchase so I would buy the "best" I could recognise. Strangely the really expensive brand name versions were not available, whilst the cheaper sets were. My issue has been hesitation resulting in engine management light coming on when the weather is really cold, the vehicle is very cold and my first km of the trip is uphill. I dont know whether this will fix it but I will see.
Regarding the compression, thanks for the tip, I will look carefully, but without jinxing the vehicle, it runs really well and I never seem to have a speed issue. I travel at 70mph no issues, and certainly manage to overtake OK. I am used to driving bakkies not BMW sports models, so maybe my frame of reference is more the tractor version than the ferrari.
At 45mph (it has a mph dial, wish I could change to kmh) I get the slight wobbles which dissapear at 55mph. That will be the final big ticket item to address. All part of the fun!
Julian
2008 Gen 3 Manual
22 Feb 2024 17:52 #254518
Thats sounds like a good deal on the coils and leads. Both Hella and Ridex are decent brands and as you say fit it once then never look again.
I don't suppose you would have saved much by buying cheaper un-recognised brands.
Your wobble sounds as if it could be king pin bearings. Easy way to check, jack the wheel and test for [vertical] up and down movement. If it has up and down movement the king pin bearings need doing. If it is side to side, it is usally something else, possibly linkage or wheel bearings.
Also have a look at the large knuckle seal, is it leaking oil? When the king pin bearings go, the drive shaft oil seal also goes and this allows diff oil to flow in to the knuckle and leak past the [dust] seal.
See www.bigjimny.com/mediawiki/index.php/King_pin_bearing_change
It's not a difficult job and Martin keeps the bearings in stock in the BigJimny store. I suggest getting the full kit including shaft oil seal and large knuckle seal as these are often in a poor state.
Robin
Robin
22 Feb 2024 20:26 #254524
by JAGtheman
Julian
2008 Gen 3 Manual
In Germany (because there are 100 laws preventing you touching your vehicle in case you make a mess), you can hire fully equipped garages where you can do complex things like washing the car without being carted off by the cops. I have battled to find similar here where I could tackle such a job. I need a ramp!!
My facilities are pretty limited and are outside, so the weather is also an issue. I am having the aircon redone on Monday replacing the pump with one I imported from China. Waste of money I suppose, should have done the kingpins instead but tbh I forgot! There is sun predicted for the weekend so these leads and some underbody sealing is on the menu. Followed by a well earned run in the vehicle!
Julian
2008 Gen 3 Manual
24 Feb 2024 08:52 #254538
by Phaeton
Replied by Phaeton on topic Replacing ignition lead set
You don't need a fully equipped garage to do the kingpins, it can be done on the drive with a jack, axle stands & basic tools
- rogerzilla
24 Feb 2024 10:47 - 24 Feb 2024 10:48 #254540
by rogerzilla
Replied by rogerzilla on topic Replacing ignition lead set
I think the point is that the German authorities don't allow some work to be done at home because it brings down the neighbourhood to have some guy ripping the engine out of a Ford Taunus on his driveway. In some German states it's not even legal to wash your car at home on a Sunday.
Some estates in the UK have covenants that prevent car maintenance on the driveway, but these are roundly ignored.
Last edit: 24 Feb 2024 10:48 by rogerzilla.
Time to create page: 0.106 seconds
