Noises when steering in 4WD
08 Jan 2024 20:38 #253371 by Roger Fairclough
I believe what moadi means is that the hubs are permanently locked in but 4 wheel drive has not been selected within the T.box.
Roger
The following user(s) said Thank You: moadi
09 Jan 2024 04:20 #253376 by Lambert
Replied by Lambert on topic Noises when steering in 4WD
In which scenario as I have attempted to describe the wheels are making the front driveline move instead of the driveline making the wheels move. Therefore in each state the loading applied to the cv is in a different direction and is likely to produce different noises.
09 Jan 2024 08:42 #253378 by moadi
Replied by moadi on topic Noises when steering in 4WD
I see what you mean, makes sense, I will take out the CV joint later this weekend to check for signs of wear
Thanks
Time to create page: 0.348 seconds
