Noises when steering in 4WD
07 Jan 2024 17:01 - 07 Jan 2024 17:02 #253332 by moadi
Hello everyone,
So I’ve recently been hearing noises and they’re getting worse whenever I turn almost the maximum, I’d say anything above 70% steer.
I don’t know how to describe it but it sounds like something is grinding with ticking.
When I steer in 2WD it’s ok even when my lockers are on 4x4.
Any ideas? Thanks
Last edit: 07 Jan 2024 17:02 by moadi.
07 Jan 2024 17:19 #253333 by Lambert
Replied by Lambert on topic Noises when steering in 4WD
Sounds suspiciously like a cv joint. It being quieter with the hubs in 4x2 suggests the when the wheels are turning the cv joints they are not running on the worn parts of the joint balls.
The following user(s) said Thank You: moadi
07 Jan 2024 17:41 #253334 by jackonlyjack
i agree with Lambert also would advise fixing it soon
cos when it breaks you will struggle to turn making it almost impossible to drive home
07 Jan 2024 18:06 - 07 Jan 2024 19:24 #253336 by DrRobin
Replied by DrRobin on topic Noises when steering in 4WD
A clicking or even a sort of cracking sound at full lock is a sure sign of a cv joint on the way out. Is it coming from both wheels or just one?
The only other thing, are you running bigger tyres, they might be catching on the wheel arch, especially if like me the front bumper was pushed back after dropping in to a rut whilst off roading, usually the sound of a cv is different?
Last edit: 07 Jan 2024 19:24 by DrRobin.
  • rogerzilla
07 Jan 2024 19:09 #253339 by rogerzilla
Replied by rogerzilla on topic Noises when steering in 4WD
Checking the obvious, are you on a loose or slippery surface?
08 Jan 2024 09:21 - 08 Jan 2024 09:31 #253343 by moadi
Replied by moadi on topic Noises when steering in 4WD
The thing is that I have fixed hubs so they’re always on 4x4 and it makes noise only when I’m actually in 4WD but when the lever is on 2H and I steer it doesn’t make the noise even with the hubs locked
_________________________________
I believe its only the left one but I will lift both front wheels up and check
Normal tyres, just bigger engine which I believe contributes to wearing CVs right?
I heard it many times on asphalt, I’m not entirely sure about slippery surfaces, if I don’t hear it on slippery surface what does that mean?
I see, hope I can find a CV joint without having to buy the whole rod
Thanks everyone
Last edit: 08 Jan 2024 09:31 by moadi.
Time to create page: 0.192 seconds
