Help wiring tracker
23 Dec 2023 09:34 #253022
by Jimbo98
Replied by Jimbo98 on topic Help wiring tracker
Yeah its not that big however they recommend attaching it to the battery but whats the point in that. Thats the first place they would look!
23 Dec 2023 21:08 #253029
by Jimbo98
Thank you for the help! I ended up doing this today which worked fine then used one of the mirror screws for a ground. No issues as of yet.Don't know how big the tracker is, but there's a permanent live at the light by the mirror, if it's small enough could it fit up under the headlining or possibly in the channel above the screen. There's also a live at the central locking unit which is at the side of the glovebox if you need a bit more space
23 Dec 2023 21:14 #253031
Replied by jackonlyjack on topic Help wiring tracker
Good to see you sorted it
But you have given a good idea where you've fitted it not a good idea imo
23 Dec 2023 21:19 #253032
by Jimbo98
Yeah, that's true however I created a new account on here just so the profile shouldn't link back to me in any way. Do you happen to know anything about kill switches? If so can I PM you?Good to see you sorted it
24 Dec 2023 10:30 #253039
Not so much about kill switch
I have after market alarm
pedal lock home made
kryptonite wire loop with padlock
for kill switch just remove a connection see if it starts
when you find one that doesn't allow car to start,connect a rocker switch rated to 30amp
hide the switch where you like
24 Dec 2023 13:23 - 24 Dec 2023 13:23 #253042
by Phaeton
As to a kill switch what are you wanting to kill? The whole car, you can get one of the big switches like they use on Rally cars that have the big red key, problem is they are all the same big red key. You can get a remote switch which disconnects the battery via a fob (search temu & fleecebay), but problem with that is you are forever resetting the clock, it's also easy to bypass. You could interrupt the starter low voltage side & bring back up to a switch. One of the ones I do is put a switch in the coil that goes around the ignition barrel that way it doesn't detect the key & leaves the car immobilsed even if they have stole the key, there are usually 2x small black wires, not looked but presume the Jimny uses the same system. Failing that I have insurance so that if some scrote does take it, at some point the corrupt insurance company will give me some money back.
Replied by Phaeton on topic Help wiring tracker
Although possible what are the chances of a chancer finding THAT specific car that has the tracker hidden there, where do you live to need all that security, my wife left her keys in the ignition of her car last night it was still here this morning & I would expect 360 out of 365 nights a year for it to still be there.Good to see you sorted it
Last edit: 24 Dec 2023 13:23 by Phaeton. Reason: Spilling mustake
