Help wiring tracker
22 Dec 2023 15:22 - 23 Dec 2023 21:21 #253009 by Jimbo98
Help wiring tracker was created by Jimbo98
Hi Guys,
My car has been broken into this week however they haven't managed to steal it from some extra measures I put in without going into detail. I want to install a tracker & a kill switch to make it as awkward as possible if they do manage to hot-wire it.
I want to know where all the permanent lives are in the car so I can hide my tracker the best, I understand that people might not want to let the whole internet know so if you know where they are please message me if you can on here. The car is a Jimny 2003.
Thanks for the help
Last edit: 23 Dec 2023 21:21 by Jimbo98.
22 Dec 2023 17:59 #253011 by Lambert
Replied by Lambert on topic Help wiring tracker
My tracking system uses so little power it's able to hook into any live without issue. Plus it has a backup battery too even if it live happens to be found or accidentally cut. Good luck hiding it.
22 Dec 2023 18:03 #253012 by DrRobin
Replied by DrRobin on topic Help wiring tracker
I had a cut out switch on a Vauxhall years ago. I used one of the spare dashboard switches, just removed the blank and bought a switch to match. Rather than cutting the main power I inhibited the ignition so the starter motor would turn but the engine wouldn’t start.
It’s less obvious than a full cut out and it was effective I caught four joy riders in it one morning.
My 2011 has an immobiliser fitted as standard, did the 2003 have one?
Robin
22 Dec 2023 19:47 #253013 by Phaeton
Replied by Phaeton on topic Help wiring tracker
Don't know how big the tracker is, but there's a permanent live at the light by the mirror, if it's small enough could it fit up under the headlining or possibly in the channel above the screen. There's also a live at the central locking unit which is at the side of the glovebox if you need a bit more space
The following user(s) said Thank You: Jimbo98
22 Dec 2023 20:19 #253015 by mlines
Replied by mlines on topic Re:Help wiring tracker
Front headlamp
Sent from my ThinkPhone by motorola using Tapatalk
23 Dec 2023 09:31 #253021 by Jimbo98
Replied by Jimbo98 on topic Help wiring tracker
Thank you, I'll check this out today
Time to create page: 0.164 seconds
