Chip tuning is it working?
13 Dec 2023 19:00 #252852
by Ulltand
Chip tuning is it working? was created by Ulltand
Hello everyone!
What about chip tuning, is it working? If so why dont we all have it? I could 20 hp extra out of my DDIS according to the adds.
- rogerzilla
13 Dec 2023 20:49 #252855
by rogerzilla
Replied by rogerzilla on topic Chip tuning is it working?
With just a chip, you won't get an extra 20bhp and pass an emissions test. If you also change the exhaust system, throttle body, injectors and cams, maybe!
Turbo cars can get enormous increases from chipping because the boost can be increased - just hold the wastegate shut for longer.
- Thank you received: 678
13 Dec 2023 22:06 #252857
Replied by DrRobin on topic Chip tuning is it working?
Roger is correct, whilst some engines can be chipped and get increased power and better fuel economy (at the expense of emissions) unfortunately an engine like the Jimny doesn’t. So take the claims of 20hp and divide between 5 or 10 and you might get a more realistic improvement, if any at all.
Some of these ‘chips’ are nothing more than a resistor that goes in the mass flow sensor and fools the ecu in to pumping more fuel in to the engine, they don’t do very much.
Even a full remap of the ecu might not gain 20hp. That’s why no one does it.
Robin
Robin
- Thank you received: 2005
14 Dec 2023 04:27 #252860
Replied by Lambert on topic Chip tuning is it working?
As you say a ddis I assume it's not a uk car but one of the French diesel engines, in which case yes a chip would help no end. Unfortunately I don't know enough about the diesel engines to suggest which chip would be best.
14 Dec 2023 13:57 #252874
by Busta
Replied by Busta on topic Chip tuning is it working?
If I had a diesel Jimny I'd definitely get it re-mapped. The 1.5 engine is popular in many other vehicles so the potential gain and any downsides will be well documented.
There's very little to gain from re-mapping the petrol engines (the only option in the UK) so we opt for engine swaps instead.
The following user(s) said Thank You: Ulltand
Time to create page: 0.153 seconds
