Bumper Removal Towbar fitting
05 Dec 2023 08:28 #252634 by Phaeton
Have a towbar to fit should be fun as I don't have the correct bolts with the arms on, sure I can improvise, but before I get to that point I have to remove the rear bumper to get to the ends of the chassis rail. Is it easy, is it straight forward or an absolute barstool only to be tried when there is plenty of time?
05 Dec 2023 08:37 #252636 by DrRobin
It’s easy to remove, there are a few online videos if you do a search, but mostly the fixings are obvious. Taking the bumper off will be one of the faster jobs, fitting the wiring will take longer.
Get something to rest the bumper on when you release it, the cable goes the near side and is not super long. You will need to swing it to one side to fit the tow bar.
The special bolts go inside the rails and the tabs hit the rail sides so you can tighten the up from the outside. You can do the same thing with a ring spanner.
Robin
The following user(s) said Thank You: Phaeton
05 Dec 2023 13:47 #252638 by Phaeton
Thank you very much Robin, I was hoping I can use normal bolts & fish them through the holes, or blutac them into a ring spanner etc.
Alan.
05 Dec 2023 14:49 #252639 by Scimike
I'll second what Robin said, very easy job to do once the bumper is out of the way.
it's slightly easier if you can put the rear of the car on ramps or axle stands, but not essential. It just saves you laying on you back, turns into a sitting down with coffee sort of job that way.
Depending upon the make of towbar and your current exhaust clearance can be a little tight between the two. My aftermarket rear silencer hung at an angle, I needed to bend the mounts on this to get it level to prevent "knocking". Again not difficult, but something you may need to correct if you have the issue.
Mike
05 Dec 2023 15:27 #252642 by 300bhpton
Alan.
Make sure you use the correct grade bolts. Minimum of 8.8 or maybe even 10.9, they must be high tensile. Don't use stainless ones.
The right size is also important.
06 Dec 2023 04:46 - 06 Dec 2023 04:46 #252655 by Busta
Replied by Busta on topic Bumper Removal Towbar fitting
Very easy, mostly 10mm fixings in the boot opening, wheel arches and a couple on the underside. You need to remove the upper tail lights too access the last 2 and once the bumper is loose you can disconnect the wiring with 2 connectors behind a rubber flap on the left hand side. Saves having to leave the bumper hanging around!
Last edit: 06 Dec 2023 04:46 by Busta.
