Jimny unlock doors
- Thank you received: 662
02 Dec 2023 17:43 #252586
Replied by DrRobin on topic Jimny unlock doors
Each door has a motor to lock/unlock, it sort of kicks the mechanism open or closed. Turning the key in the drivers door mechanical kicks the mechanism and then closes a switch contact which locks/unlocks the other doors.
I would have thought a 2006 would have the central locking control box and all that is missing is the transmitter key. If you get a key you will need to program it in.
You are right about the two wires, I tapped in to mine and put a latching relay on them, when the doors are unlocked they close the latching relay and it starts up my stereo head unit and then switches off the stereo when I close the doors, rather than from the ignition which is the more common line to use. Idisthis mostly as the head unit takes 30 seconds or so to start up, but also so I can have the stereo on without the ignition switched on.
Robin
Robin
04 Dec 2023 19:38 #252623
by Phaeton
Replied by Phaeton on topic Jimny unlock doors
Have you seen my entry in this post
www.bigjimny.com/index.php/forum/7-jimny...mote-central-locking
04 Dec 2023 23:21 #252627
Then the suzuki shop tried, but appears many jimnys come without any reciever.
Not difficult to hook up the aftermarket unit.
Replied by yakuza on topic Jimny unlock doors
I thought so too and bought one original fob and tried to get it programmed, but nope.
Robin
Time to create page: 0.150 seconds
