Jimny unlock doors
30 Nov 2023 16:16 #252504 by Dimitris
Jimny unlock doors was created by Dimitris
Hello
I got a Jimny 2005. It has no remote control to unlock the doors but when I unlock the driver s door with the key, it unlocks all the doors. Propably there is some kind of motor to the passenger door and the rear one. Is there a motor to the driver s door too?
30 Nov 2023 16:30 #252507 by Phaeton
Replied by Phaeton on topic Jimny unlock doors
I'm hoping so, I've just would a Chinese unit to open/closing unit
The following user(s) said Thank You: Dimitris
30 Nov 2023 16:39 #252509 by Darthblaker7474
Replied by Darthblaker7474 on topic Jimny unlock doors
When you unlock the driver's door by putting the key in the lock, and all the doors unlock as well, you have central locking fitted.
You may be able to retrofit the remote central locking module to your car, and then just programme a new set of buttons to it.
30 Nov 2023 19:17 #252517 by Dimitris
Replied by Dimitris on topic Jimny unlock doors
I found this diagram. If it is right then I see that the motor is using two cables so it will be easy to make ot work
30 Nov 2023 19:53 #252519 by Phaeton
There are 2 different motors from the diagrams I've seen, 2 wire & 4 wire.
02 Dec 2023 17:17 #252584 by Dimitris
Yes but I think red and black cables are the motors voltage. The other two are like position sensor
Time to create page: 0.297 seconds
